Originally posted by ****
Hi all,
I was looking into the the XML file import for the sequencer in Xpression. Hence I did not find a description on the file format. Has anyone got this information?
regards
Tom
Hi all,
regards
Tom
Create a sequence, export it, and look inside the file ![]()
@Vincent:
I had this idea also, but there is no Export in XML format available in the software, ONLY .txt format.
So the question is still open!
Oh yes, sorry ! ![]()
I also am interested in this subject.
Please download the following files and have a look at the structure. I’ts pretty self explanitory if you can understand an xml file structure.
https://rossvideo.centraldesktop.com/xpression/file/19232514/
https://rossvideo.centraldesktop.com/xpression/file/19232416/
Sorry everyone but my earlier post included links that may not work.. please follow these links…
https://rossvideo.centraldesktop.com/p/eAAAAAAAAOOLAAAAAAeYIZU
https://rossvideo.centraldesktop.com/p/eAAAAAAAAOOOAAAAAGkpyfM
Hello Jim,
thanks for the information.
Are there also tags available to set the group behaviour (Timed, Manual, Color) and for the items (TransIn, TransOut, Duration)?
regards Tom
I LOVE YOUUUUUUUUUUUUUU JIMMMMMMMMMMMM!!!
The only XML commands available in the XML file import at this time are: create, delete, creategroup and clear.
You can set up a watch folder in the XPression Preferences which will automatically import the new playlist into the sequencer when the XML file is updated. In the Preferences there are some options to control the behaviour of the XML file import from the watch folder.
Can u provide a little example for clear command?TNX
