I am using xpPublishedObject.SetPropertyString to insert a character into a static text field in the sequencer. The script appends a character to the end of whatever was in the text field to begin with. Whenever I run the script from the keyboard that inserts the character, it sets the cursor position back to the beginning of the line. Is there any way to make the cursor position stay, or to force the cursor to the end of the line instead? It’s annoying to have to hit the end key every time the cursor resets.
Can you provide your version, build and a sample script that has this problem?
10.5 build 5543.
dim input as string
dim obj as xpPublishedObject
dim initial as string
engine.Sequencer.GetFocusedPublishedObject(obj)
obj.GetPropertyString(0, initial)
input = InputBox(“Enter the number of the character you want to insert.” & VbCrLf & VbCrLf & " 1: +" & VbCrLf & " 2: Á" & VbCrLf & " 3: á" & VbCrLf & " 4: É" & VbCrLf & " 5: é" & VbCrLf & " 6: Í" & VbCrLf & " 7: í" & VbCrLf & " 8: Ó" & VbCrLf & " 9: ó" & VbCrLf & “10: Ú” & VbCrLf & “11: ú” & VbCrLf & “12: Ü” & VbCrLf & “13: ü” & VbCrLf &“14: Ñ” & VbCrLf & “15: ñ” & VbCrLf & “16: © (Copyright)” & VbCrLf & “17: • (Circle Bullet)” & VbCrLf & “18: ½ (One Half)” & VbCrLf & “19: ¼ (One Quarter)” & VbCrLf & “20: ⅓ (One Third)” & VbCrLf & “21: ⅔ (Two Thirds)”,“Insert Special Character”,“”)
if input = 1 then
obj.SetPropertyString(0, initial + “+”)
else if input = 2 then
obj.SetPropertyString(0, initial + “Á”)
else if input = 3 then
obj.SetPropertyString(0, initial + “á”)
else if input = 4 then
obj.SetPropertyString(0, initial + “É”)
else if input = 5 then
obj.SetPropertyString(0, initial + “é”)
else if input = 6 then
obj.SetPropertyString(0, initial + “Í”)
else if input = 7 then
obj.SetPropertyString(0, initial + “í”)
else if input = 8 then
obj.SetPropertyString(0, initial + “Ó”)
else if input = 9 then
obj.SetPropertyString(0, initial + “ó”)
else if input = 10 then
obj.SetPropertyString(0, initial + “Ú”)
else if input = 11 then
obj.SetPropertyString(0, initial + “ú”)
else if input = 12 then
obj.SetPropertyString(0, initial + “Ü”)
else if input = 13 then
obj.SetPropertyString(0, initial + “ü”)
else if input = 14 then
obj.SetPropertyString(0, initial + “Ñ”)
else if input = 15 then
obj.SetPropertyString(0, initial + “ñ”)
else if input = 16 then
obj.SetPropertyString(0, initial + “©”)
else if input = 17 then
obj.SetPropertyString(0, initial + “•”)
else if input = 18 then
obj.SetPropertyString(0, initial + “½”)
else if input = 19 then
obj.SetPropertyString(0, initial + “¼”)
else if input = 20 then
obj.SetPropertyString(0, initial + “⅓”)
else if input = 21 then
obj.SetPropertyString(0, initial + “⅔”)
else if input = “” then
else
MsgBox(“Invalid input.”,0,“Insert Special Character”)
end if
