During Ross Live 1.0 there was a session in regards to the XPression Dashboard Preview Client. I remember the trainer saying goto www.IDON’T-REMEMBER.com to download one file before changing all the settings in XPression.
Does anyone remember what the website address is? Or better yet which webinar the example was in?
I was not at the Ross Live event, but I can point you here:
https://www.rossvideo.com/gallery/xpression-u/xpression-and-dashboard-creating-xpression-preview-client-in-dashboard/
I asked our XPression Product Manager about it, and he said the following:
I assume they are sending the users to www.rossvideo.com/dashboard to get the latest Dashboard installed before changing the IP addresses in the
Edit>Hardware Settings><Inputs / Outputs>Add> XPression Desktop Preview Client
The settings dialog box will prompt for the Host (IP Address or UNC) of the computer that will receive the Preview Output Stream
From there, in the same Hardware setup panel, the user selects the Preview & Monitor tab and assigns the desktop preview client to be the assigned preview output for the Physical channel.
Here is the Dashboard Grid File which is used in the tutorial
https://www.dropbox.com/s/1o8s4b3th3ogrd1/XPression%20Preview.grid?dl=0
Thanks Ben! I will look at the video again I just couldn’t remember which session it was!! I have done all the steps you have posted but it’s a 3rd Party Driver that they mentioned in the video you needed to download and install to allow use on Dashboard Preview Client.
