xPression preview window/3rd framebuffer into Carbonite Ultra Switcher
Is there a tutorial available for adding a specific framebuffer as a input into a Carbonite Ultra switcher? I know how to set the preview framebuffer, but adding it into the switcher is tough for me. Any advice?
Hi Zachary,
The principle of the system is to create the graphic that you want on XPression. Once created, you then transfer that XPression graphic (still) to a Media Store in Carbonite Ultra using FTP..
Once you have created the graphic and you want to transfer to a Carbonite Media Store, you will see a section where you can select which Media Store the graphic will be sent to.
I hope that this helps you.
