I recently worked a job that had Xpression 9.5 and was still using Xpression Video Coder v1.
I built my graphics package on Xpression 10.5 using the newer Xpression Video Coder v2.
Because of the codec, the animated graphics would not transfer over to the 9.5 project.
Is this as easy as downloading the newer codec to the older machine or do you have to re-transcode all the animations again using Video Coder v1?
You can install the XPVC2 codec onto any older XPression software and it will properly playback XPVC2 video files.
This works, but is not officially supported.
Where do I download the XPVC2 codec??
Garner,
Looks like you helped out Dan about a year ago with the same issue.
The download links were expired though.
Can you send new ones?
Here you go:
https://transfer.rossvideo.com/f/c48dd2283dc23cee
