Production Workflow
  • 1.  Does Overive operate in Carbonite MiniME mode?
    Posted 01-31-2016 16:46
    I'm trying to figure some things out, so a little question:
    Does Overdrive operate in Carbonite MiniME mode?
  • 2.  RE: Does Overive operate in Carbonite MiniME mode?
    Posted 02-17-2016 20:19
    OverDrive can use a Carbonite Production switcher in an automation environment when used in conjunction with Ross Videos Caprica.
    http://www.rossvideo.com/control-systems/overdrive/carbonite-integration.html
    #OverDrive
  • 3.  RE: Does Overive operate in Carbonite MiniME mode?
    Posted 03-04-2016 19:28
    Thanx Garner, i know the need for a Caprica server. But Carbonite can run in more modes, so i try to figure out if Overdrive can control the Carbonite mixer as it is in the MiniME modes, insteads of a 2.5ME mode?
    #OverDrive
  • 4.  RE: Does Overive operate in Carbonite MiniME mode?
    Posted 03-04-2016 20:03
    Ah I see. Carbonite must operate in 2.5ME mode for OverDrive/Caprica to control it. OverDrive requires a minimum of 2.5MEs on any switcher to control it.
    If you want MineMEs AND OverDrive control of Carbonite you will need a Carbonite Black Frame.
    #OverDrive
  • 5.  RE: Does Overive operate in Carbonite MiniME mode?
    Posted 03-04-2016 20:04
    Because the Carbonite Black has 3MES AND miniMEs
    #OverDrive
  • 6.  RE: Does Overive operate in Carbonite MiniME mode?
    Posted 03-04-2016 23:18
    At my last place of work we had a Vision that only had 2 ME's and was controlled by OD. It would either call up memory on ME 1 or on ME 2. If on ME 2, then ME 1's PRG source would be ME 2.
    #OverDrive
  • 7.  RE: Does Overive operate in Carbonite MiniME mode?
    Posted 04-08-2016 20:15
    Thanx Garner!
    #OverDrive
