Production Workflow
  • 1.  OD 10 floating MLE?
    Posted 03-29-2012 10:22
    We just upgraded to OD 10 and noticed that you can no longer select the floating MLE's to be MLE 2&3 it defaults to 1&2. Just wondering if this feature will be coming back in the next update of the solfware?
  • 2.  RE: OD 10 floating MLE?
    Posted 03-29-2012 18:08
    Hello Patrick,
    You are right - in OverDrive version 10, the system now selects the lowest numbered MLEs as floating, and allows you to use higher numbered MLEs as fixed. There should be no difference in the total number of floating or fixed MLEs available.
    This change was made to allow OverDrive to support the Ross Video Octane 8 MLE switcher.
    #OverDrive
