Production Workflow
  • 1.  Overdrive V 12 failover documentation.
    Posted 10-30-2014 18:42
    Is there a document available for hot failover of the Overdrive system while on the air? We run two Overdrive servers, two Overdrive clients, and one switcher. We run our studio 20 hours per day live, so hot failover is essential to our operation. Perhaps there are different directions for server or client failover? Anything would be helpful. Thanks!
  • 2.  RE: Overdrive V 12 failover documentation.
    Posted 01-09-2015 23:15
    on both your direct control and rundown control there should be a orange H in the upper right corner next to the green lights that say if you are connected or not and when you click on the orange H you can switch between servers
    #OverDrive
