Production Workflow
  • 1.  Release Notes - OverDrive Version 10.0.4
    Posted 03-30-2012 18:08
    Welcome to the release notes for OverDrive Version 10.0.4. These notes were posted March 30, 2012.
    V10.0.4 (March 2012) Enhancements
    Disabled Camera State
    Added additional camera state checks in Rundown Control to ensure that a disabled camera does not recall shot information when it transitions to on air.
    Clip duration audit correction
    Added robustness content to make the clip duration request overflow work to its maximum of 200 items
    Take and Prep Next
    Eliminate a race condition in Rundown Control associated with GPI triggered events. Rundown Control will now queue incoming GPI events and ensure processing.
    iNEWS move multiple correction
    Correction in the handling of the MOS roStoryMoveMultiple message generated when iNEWS users drag and drop a set of stories within the NRCS client. This fix keeps the Rundown Control table aligned with the running order in iNEWS
    Eliminate unexpected Custom Control popup
    Inserted a fix to ensure the Custom Control popup warning does not appear on the Rundown Control client that is running in Monitor Mode, unless that client performed a Custom Control Hot Key stroke. The monitoring client had been reacting to hot keys coming in when Direct Control had focus.
    Logging hot key in Rundown Control
    Introduced a troubleshooting enhancement where Rundown Control hot key strokes are now logged. The additional information will help in the analysis of future field issues.
  • 2.  RE: Release Notes - OverDrive Version 10.0.4
    Posted 06-12-2012 04:11
    These all sound like good advancements.
    [I]"Take and Prep Next
    Eliminate a race condition in Rundown Control associated with GPI triggered events. Rundown Control will now queue incoming GPI events and ensure processing."[/I]
    Could you please explain/elaborate on this? I use these GPI events. Is the change to prevent potential errors in the GPI events?
    #OverDrive
  • 3.  RE: Release Notes - OverDrive Version 10.0.4
    Posted 06-25-2012 18:15
    To clarify the release note:
    When multiple transitions were happening at almost the same time - for instance using a GPI to advance the rundown, while attempting to turn a downstream key on or off, the system would perform the key transition and sometimes drop the GPI.
    As of release 10.0.4, the system will now queue the GPI transition to occur after the previous transition has completed.
    #OverDrive
  • 4.  RE: Release Notes - OverDrive Version 10.0.4
    Posted 06-26-2012 22:30
    Great! thanks!
    #OverDrive
