I'm running Overdrive v18.1, Overdrive v12
I have a Custom Control that recalls a a clip from Blackstorm, plays it, transitions using a simulate GPI command, etc....
All is fine and well until the last command which is a 'Cut Key' that turns key 4 off (The keyer the blackstorm is on)
Except that Key 4 doesn't turn off and the Custom Control on the Overdrive Custom Control window remains lit green with no way of shutting that off..
The only way i have found to shut it off is by going into the Edit Custom Control and Running that Single Event
I've tried lengthening and shortening the length of the pause between the 'Simulate GPI' and the 'Cut Key' command with no success.
Any ideas what's going on here?
