Production Workflow
  • 1.  Direct Control: Changing Multiple Settings for Multiple Shots
    Posted 10-09-2012 19:20
    We recently changed some settings on our robotic cameras and I need to be able to change the iris for all of my shots without having to manually pick the shot and then set the iris. I also have no way of getting exact settings for my iris (seeing how there is no numbered readout for the iris setting). I want to be able to accurately set my iris to exactly what I need. If this information is stored somewhere in a config file that i can maually change that would also work. But I currently don't know a way to set the iris without having to manually set it for every single shot.
  • 2.  RE: Direct Control: Changing Multiple Settings for Multiple Shots
    Posted 10-18-2012 13:57
    Hello Jacob,
    The camera recall values are saved in the camera itself - OverDrive does not have access to individual parameters and values, it simply recalls the position saved into the camera.
    Allan.
    #OverDrive
