I am trying to create device that when called will load a primary crosspoint, but if the primary is in use will alternatively load into a redundancy crosspoint. Currently, when called, it loads into both primary and redundant crosspoints, at the same time. I need it to load into one if\then the redundant.
FYI this is version 15.8.7 build 120 of Overdrive.
