Production Workflow
  • 1.  ME3 clean feed
    Posted 01-14-2017 00:19
    Is there a way I can route ME3 clean feed into my AUX bus? I have an VISION switcher and am using Overdrive. Thanks guys!
  • 2.  RE: ME3 clean feed
    Posted 01-20-2017 13:30
    You absolutely can. First you have to put the clean feed on the bus map and then use a custom control to select the source on the aux. The custom could be tied to a template and run automatically or manually a number of different ways.
    #OverDrive
