Production Workflow
  • 1.  Animated Transitions on a Synergy 3 with OD 10
    Posted 02-20-2015 16:46
    Looking to incorporate some animated transitions that have keys on an older Synergy 3. I can get the board to do the transition using a downstream keyer. Just looking for ideas on incorporating it into Over Drive. Is the only way to do a GPI from the board to the OD that triggers a take on OD with a CC. I did something similar with a vision but fishing for different ideas.
    Thanks,
    Steve
  • 2.  RE: Animated Transitions on a Synergy 3 with OD 10
    Posted 03-02-2015 06:11
    This might be clunky or not at all what you're looking for but, you could build an "audio-only" template that auto fires the CC. Of course if you are looking to transition from one template to another that probably wouldn't work.
    #OverDrive
  • 3.  RE: Animated Transitions on a Synergy 3 with OD 10
    Posted 03-08-2015 22:21
    Hell Steve,
    You are right, in that a GPI connected between the Synergy to OverDrive server is the only way to trigger OverDrive to "take and prepare next" when you run an interstitial transition on the Synergy switcher.
    #OverDrive
  • 4.  RE: Animated Transitions on a Synergy 3 with OD 10
    Posted 03-11-2015 14:45
    The GPI is to the server not the client?
    #OverDrive
  • 5.  RE: Animated Transitions on a Synergy 3 with OD 10
    Posted 03-11-2015 17:39
    That's correct.
    #OverDrive
