Production Workflow
  • 1.  First Server Template
    Posted 03-11-2015 14:38
    I'm running Overdrive 12 with Qseries
    Up until a few days ago, if a server item in the Q Series rundown wasn't coded, Overdrive would default to the first server template. However for some reason this stopped. Now if a line isn't coded, it will not appear in Overdrive.
    And way to fix this?
  • 2.  RE: First Server Template
    Posted 03-11-2015 15:57
    Good morning, Favian!
    Does any template/shot appear in an uncoded Q Series rundown line? I'm wondering if the first server template was moved within Template Editor.
    -Mike
    #OverDrive
  • 3.  RE: First Server Template
    Posted 03-11-2015 16:04
    No, it shots wouldn't normally appear uncoded.
    However, the lines with a video clip would default to the first Server template. I made a "Not Coded" template and video clip lines would default to this "Template", sort of as a flag.... It would alert the coder to then code it with the appropriate template.
    I did recently move the first server template. (used to be template 195, now 190)
    #OverDrive
  • 4.  RE: First Server Template
    Posted 03-11-2015 16:30
    Just out of curiosity, what resides now at template 195? If it's a template that's server related, does that template/shot auto-populate within Rundown Control?
    #OverDrive
  • 5.  RE: First Server Template
    Posted 03-11-2015 16:59
    195 is a SOT template. it is server related but doesn't auto-populate.
    #OverDrive
  • 6.  RE: First Server Template
    Posted 03-11-2015 17:44
    I may have just resolved my own issue. In the template editor the Device names were different i changed those back to SRV, SRV C, and SRV D. And thats seems to have resolved my issue.
    #OverDrive
  • 7.  RE: First Server Template
    Posted 03-11-2015 20:14
    Glad to hear that things are back to normal.
    -Mike
    #OverDrive
