We do offer an interface called "QuickTurn" that lets the script editor tag material for web publishing in the newsroom and use OverDrive to drive the media encoder to record/pause in real time during the broadcast. Typically, this is used to segment a newscast into stories rather than run a full live stream.
What type of encoder are you using?
#OverDrive
