[QUOTE=jwhitwill;n9780]Streamline comes with a copy of Telestream Vantage for generating proxy and thumbnails as assets are ingested. Normally the system is commissioned with that workflow already configured - if it is not currently working our technical support team should be able to help get it set up for you. Depending on the file format and codec Vantage may not be able to transcode the particular video file you are ingesting. Ensure that the file can be played back on the Streamline server. The setup procedure for Streamline with Vantage is fairly involved so it might be best to have a member of our support team TeamViewer into your system to see how it is set up currently and make any configuration changes that are necessary.[/QUOTE]
I'll check with our Engineers and see if Telestream Vantage was configured. The videos are being encoded using XPression Video Coder (I believe Codec 6.2). We were told to encode lossless movs through it. All of those clips cannot be previewed in Streamline, nor do they have a thumbnail that generated. There are a couple of clips that our hub put in that are not .avi using that codec. They are .mp4 with the rle Codec, and those preview in Streamline and generate a thumbnail. If the Telestram Vantage is installed, do you have any other suggestions? I've tried using the Xpression Codec while rendering in After Effects CC 2015 with those same results.
#Streamline
