When you report "some of the shots have disappeared", do you mean the camera shot (robotic cam shot number) or the actual template is gone?
Do the quick recalls still reside in the quick recall shot box gui? Have you changed the template numbers?
I am on a version of V12. I will build a rundown tomorrow with quick recalls and look to see if it recalls fine.
One other question...are you using user profiles? Or does everyone use the same profile?
#OverDrive
