Hi rgba32bit,
Where exactly are you trying to edit your Assets? Is it in the grid? Or the details view?
If it's the details view, are those fields configured to be editable? You can see this by doing the following:
1. Go to the "Configuration" menu (gear icon under Tools)
2. Go to the "Metadata" sub menu (notepad with the 'i')
3. Select the "Asset" entity and click "Manage Forms"
4. Select the "Details" form and hit "Edit"
Here you will be able to modify the fields you see within the Asset Details view. Ensure that the fields you want to edit do not have "Read-only" checked.
#Streamline
