Production Workflow
  • 1.  DMX control of lighting
    Posted 03-01-2017 16:24
    Is it possible to control DMX lighting from Overdrive?
    UDP strings or something more sophisticated?
  • 2.  RE: DMX control of lighting
    Posted 03-01-2017 17:11
    Could be a couple of different methods. We can send triggers over UDP but there can be fader commands in the protocol, so typically we are doing preset calls over GPO.
    What hardware are you using currently to control the lighting?
    #OverDrive
