Production Workflow
  • 1.  How to make a monitor panel with a RCP-NK1
    Posted 04-02-2013 16:21
    Does anybody know how to make a monitor panel with a RCP-NK1...
    We have 1 button on the dest. panel that is the monitor output, but we want to make a separate panel to switch between te inputs with a other RCP-NK1 instead of the button.
    They all connected with a NK-ISP on a NK-3G34 Router.
  • 2.  RE: How to make a monitor panel with a RCP-NK1
    Posted 04-04-2013 15:26
    [We've moved this question into the NK Routing Systems category]
    On the monitoring panel, you can configure the buttons as Crosspoint type, with a specific input/output/breakaway. This button will light whenever that particular switch is active. You can also set the "Panel Locked" option so that the panel only monitors status, but does not send switches.
    Hopefully this solves the problem, if you have further questions, please ask here, or contact our Tech Support.
    #OverDrive
