Production Workflow
  • 1.  Red CC (Custom Control)
    Posted 03-12-2019 22:46
    Hi all,
    I tried searching for a solution before making this post but I am wondering if there is an easy way to identify where this custom control in the photo I've attached is located in a template (bottom of photo Bank 48, Button 48). Is there an easy way to find it? Perhaps without double clicking on all my templates individually in TemplateEditor? Red means its invalid but does it also mean it is being used somewhere or in a template already?
    thanks so much!
  • 2.  RE: Red CC (Custom Control)
    Posted 03-13-2019 15:15
    You are correct. The red indicates that this custom is being referenced somewhere in the system. It could be in your Quick Recalls, your shots, your master rundowns, or your master templates. Sometimes, if you have a backup of your system, it is useful to recall a backup to see what that custom control might have been in order to find out where it may have been used.
    #OverDrive
  • 3.  RE: Red CC (Custom Control)
    Posted 03-14-2019 19:46
    thanks JB.. I just wish it was easier to locate. I've been clicking through all the templates & shots & QRs & I can't find the darn thing. thankfully it was (I believe) a test CC made a while back but it somehow got added into somewhere.
    #OverDrive
  • 4.  RE: Red CC (Custom Control)
    Posted 03-14-2019 20:10
    Check the coding client, if you have one, or the redundant client. I hear you, hunting down those customs can be tedious.
    #OverDrive
