Production Workflow
  • 1.  Force Effect to MLE 3
    Posted 06-11-2020 20:22
    I want to create an effect to push to an aux (monitor).
    Don't want to take this effect full.  Just want it to work in MLE 3.
    Is this possible in Overdrive?
  • 2.  RE: Force Effect to MLE 3
    Posted 06-11-2020 20:27
    Hi David,
    What kind of switcher are you using? What version of OverDrive?
    #OverDrive
  • 3.  RE: Force Effect to MLE 3
    Posted 06-12-2020 16:00
    Thanks for the quick response.  Putting my switcher info here in case it helps someone else later.
    VISION 2X  18.1q
    Overdrive version 15.8.12
    build 164
    #OverDrive
  • 4.  RE: Force Effect to MLE 3
    Posted 06-19-2020 18:44
    Thanks for the help!  Glad it was an easy fix!
    #OverDrive
