Hello Michael,
There is a way to do a "cold" swap in OverDrive/Caprica, that might work for you.
- In the Caprica Port Configuration for your video servers,in the network configuration, click "Alternate" and enable
- Add an alternate IP to your other video server
- In Caprica you can create a CC with a Special action to swap the connection
- You can then combine it with the CC for the Ultrix Salvo for the input change in your Carbonite
- Reprepare manually the next video server once you have done the swap
Hope this helps, if you need more support, feel free to contact our tech support team and they can help you set this up remotely.
Andreanne Tremblay
Senior Solutions Specialist, Production Workflow - OverDrive
Reading, United Kingdom
Sent: 05-01-2026 15:31
Subject: Carbonite Ultra Device Swap
I have the first two set up as devices. Adding two more, but I don't have enough physical inputs on the Carbonite to add them in. If I make the next two setup as virtual inputs, can I do a device swap then?
Michael Fisher
Sr. Production Automation Director
Bellmedia
Toronto Canada
Sent: 05-01-2026 09:08
Hi Michael,
Are you controlling your VTRs as devices in the Carbonite Ultra?
And the Ultrix?
Andreanne Tremblay
