Hi again Nick,
So I did some testing and I could recall a scene with a memory, using my method, with Scenes as source on an ME bus. The only problem I faced is that Overdrive doesn't see any Scene in the list of sources, so I had to pass it through an Aux. But I haven't tried to set Ultra Scenes as fixed ME.
Good luck!
Sorin
Sorin Podeanu
technical director
Euronews Romania
Sent: 04-18-2025 02:31
Subject: Carbonite Ultrascene with Overdrive
Hi Nick,
As far as I know you can save a scene as a memory. Just make sure you disable anything else, such as MEs or Keys in the store menu.
You would than create a template in Template Editor that would recall that specific memory on a fixed ME.
I haven't tried so far to set UltraScenes as a fixed ME. I don't see any reason to do that. I would call the scene as a source on an existing ME or MiniME either with a Carbonite memory or using an Overdrive template.
Good luck!
Sorin
Sorin Podeanu
technical director
Euronews Romania
