Thanks guys for all your help and advice, I’ll have a couple of days to go through things before the first show.
Just been tense coming in as a replacement engineer and learning the entire rig, that was reconfigured and had problems with cameras and servers, but getting there, so not much time with the smaller requests with the switcher, but in a good position to fine tweak.
Many thanks for the prompt response
Kevin
Sent by a tap of a button
Sent: 4/11/2025 3:20:00 PM
Subject: RE: Creating a salvo for switching desk inputs and multi viewer boxes to match soutces
Which Switcher is this?
Note that we use the word Macro / Custom Control interchangeably. Usually the Salvo term is used with Routers. However effectively it is the same thing. A Macro event that you program a set of events to trigger all at the same time.
