  • 1.  Multiple actions in one command RossTalk to Carbonite by companion stream deck
    Posted 04-13-2026 10:00
    Multiple actions in one command RossTalk Carbonite with companion
    Hello every one
    I'm using a stream deck with bit focus companion to send command to a Carbonite.
    It works well with good syntax.
    But if I want to send two actions in the same command: it's not working. Or I can't find the good syntax to do it.
    Exemple: i want to make an autotrans PP key 1 to on
    I write KEYAUTOON ME:0:1
    If I want to make autotrans KEY 1 and 2
    I made a second action in companion without delay .Carbonite only does the last action.
    If I put delay between every command it works. But without delay it's not working
    My question is :
    in only one command in companion, can I make a multiple actions? is there a specific syntax to separate commands?
    Another way is to use a Custom Control, it works but in my case, I have many possibilities, so I want to find a way by companion.
    Any ideas ???
    Tanks for your feedback.
    Guillaume
    Davy Guillaume
    Vision Mixer
  • 2.  RE: Multiple actions in one command RossTalk to Carbonite by companion stream deck
    Posted 04-13-2026 10:02
    You can not pass multiple events all at once in one command.  It will only parse the one event.
  • 3.  RE: Multiple actions in one command RossTalk to Carbonite by companion stream deck
    Posted 04-13-2026 10:14
    In my experience, it's not possible to fire multiple custom controls from Companion simultaneously without a 10 frame delay between commands.
    Dave Marks
    Video & Tech Producer
    Crossroads Community Church
    (c) 248.732.9295 | crossroadschurch.net
    7708 NE 78th St. Vancouver, WA 98662
    On Mon, Apr 13, 2026, 7:01 AM Les O'Reilly via Ross Video Limited <Mail@rossvideo.com> wrote:
    You can not pass multiple events all at once in one command. It will only parse the one event. ------------------------------ Les O'Reilly ... -posted to the "Production Switchers" community
    Ross Video Limited
    Post New Message
    Re: Multiple actions in one command RossTalk to Carbonite by companion stream deck
    Reply to Group Reply to Sender
    Apr 13, 2026 10:02 AM
      Reply to Group Online   View Thread   Recommend   Forward   Flag as Inappropriate
    You are subscribed to "Production Switchers" as dmarks@crossroadschurch.net. To change your subscriptions, go to My Subscriptions. To unsubscribe from this community discussion, go to Unsubscribe.
    Sent: 4/13/2026 10:02:00 AM
    Subject: RE: Multiple actions in one command RossTalk to Carbonite by companion stream deck
  • 4.  RE: Multiple actions in one command RossTalk to Carbonite by companion stream deck
    Posted 04-14-2026 07:02
    As@Les O'Reilly posted, you need to put delays in between the multiple events.
    however you can also trigger a custom control from Bitfocus. you can put your commands in a single custom on the carbonite. (Just remember this command needs to exist in each set you wish to use it for)
    Happy programming,
    Tom Wilson
    Demo & Training - Solutions, Oceania
  • 5.  RE: Multiple actions in one command RossTalk to Carbonite by companion stream deck
    Posted 04-15-2026 11:21
    Thanks for yours multiple answers.
    The best way is to use a custom control.
    I choose this solution.
    Kind regards
    Guillaume Davy
    Vision Mixer
    Nantes France
