Production Workflow
OverDrive 23.3.0 Released!
  • 1.  OverDrive 23.3.0 Released!
    Posted 03-07-2025 10:57
    OVERDRIVE 23.3.0 – FEBRUARY 28, 2025
    WHAT'S NEW
    Lock Audio Variable
    Support for Electrics Friends AC2 - This product does not allow joystick control so this is a limitation of this product.
    Sony MLS X1Ability to access all Clip Stores
    IMPROVEMENT
    AMP & Omneon video servers will now eject a video clip before cueing the next video clip
    Lock Audio Variables Ability to trigger a Custom Control event to lock or unlock the audio channel assigned to the audio variable in the current active rundown.
    Enable/Disable CG Timing (Selected CG) to totally ignore NRCS updates.
    BUG FIXES
    Fixed an issue where HTML5 plugin was crashing when a large number of QuickAudio Keywords are available. (OD-20376)
    Fixed an issue where DirectControl Hot Cut Bus was not updating when crosspoints were changed. (OD-21307)
    Fixed an issue where using Task Manager to end the OD Client or the OD Client experiences a power outage the OD Client would remain in the datagrid. (OD-21338)
    Fixed an issue where after performing a install of clients and a RapidRestore the RundownControl Gateway LED would show yellow and have a "Took too long" error message in the logs and would stay yellow until a restart of the MOS Gateways services. (OD-23065)
    Fixed an issue where there was a large gap between numbers and Custom Controls when creating or editing Master Templates. (OD-23260)
    Fixed an issue where defaulted audio channel names were not visible when using the filter in an edited template or shot. (OD-23269)
    Fixed an issue where the OD Client had stopped working by adding null checks and log more information. (OD-23304)
    Fixed an issue that could cause race conditions when processing Cue in Advance. (OD-23321)
    JB Morrison
    Product Manager; OverDrive and Caprica
