Hello Scott,
From what I understand, you are looking to modify the level for the QuickAudio so that it uses 75(default). If this is what you want to do, in Template Editor, there is a tab for QuickAudio and you will find the keywords you would use in ENPS and you can select and see the level that is assigned for the Digicart.
You may want to create a new QuickAudio channel Keyword, with default level or 75 in case the original one is still needed.
Andreanne Tremblay
Senior Solutions Specialist, Production Workflow - OverDrive
Reading, United Kingdom
