So I did try to populate channel 2 of my key 1 but it's still reset my split key to an Auto select key with the source choose for channel 2 as the fill source of an Auto Select key.
I have found a way around using Custom Control attach to my memory but it would still be easier if it could work as other memory and template work with Overdrive
Sent: 01-15-2026 17:07
Subject: Split Key with Overdrive
It appears (based on the button colors) that you have taken an auto select key, and split it's signals into a fill and key so you can change the signal in the fill, but maintain the alpha signal to cut the desired shape. It's still an auto sel key, just with different signals as opposed to a graphics engine. When OverDrive recalls the memory, it recalls it as stored, but then the template sends its data and the key changes entirely over to the new signal using it's key and fill signals, breaking your split.
In my earlier screenshot, the bus assignment only shows channel 1, because it's not connected to an Acuity, but if it were, you would be able to overwrite signals in channel 1 or 2 of the key. In the case of your split key, ch1 is the BAR HD and ch 2 is the ME2ST. If you can't make assignments to the individual channels within a key from the template editor, that's what needs to be addressed. Otherwise, OverDrive will always populate the key fully instead of only the fill or key channel as you need.
What version are you on with Acuity and OverDrive?
Do you have any
JB Morrison
Product Manager; OverDrive
Sent: 01-15-2026 13:31
So I checked on the template but no luck.
Here is what happening:
I build a split key (not an Auto Select key) on the Acuity as you can see on the picture 1, Bar HD is the fill and ME2ST1 is the alpha. When I recall the memory on the switcher, it's working perfectly. When I recall it with Overdrive, I see for a second my original memory but then, it's seem that when Caprica push the source that have been assign to key 1, I loose the alpha portion of my split key and it switch back to a Auto Select key as you can see on picture 2, so I loose my alpha channel of my Split Key
Any ideas ?
Guillaume Hebert
TVA
Quebec Canada
Sent: 01-15-2026 10:16
Hi Guillaume,
Start by checking the template. Under ME's and Buses, there is the Bus Selection area, where you can choose the key and available channels to which a source can be selected. This example is from a Carbonite switcher. This screenshot is also from v24, so depending on your versioning, the UI could be different, or channel selection unavailable.
JB Morrison
