Thanks Jenn… either myself or engineering will reach out to tech support.
Out of curiosity, what are single-line string cells vs multi-line string cells?
Are there cells that you can actually have multiple lines in? Like, I know you can if you're pulling info from a script, but can you do it in a cell that you are typing in directly? Like a Shift+Enter or something?
Dave Levy
Director/TD
WRAL
Sent: 09-10-2025 04:21
Subject: Typing Text in Certain Fields in Inception Disappears
Hi Dave,
That should not be happening and should be reported to tech support so they can investigate.
When reporting, it would be helpful to know what type of custom columns you are specifically seeing problems with (ex: single line string, multi-line string). But tech support can also check this once they're on the system.
Jenn Jarvis
