Hi Mark,
I have the same problem... The default timeofday clock, runs 65 seconds ahead of the system clock.
I'm running an Ultrix Carbonite - the time of day clock on the switcher MV is correct, but the Ultriscape clock is wrong.
Does the default time of day clock in Ultriscape take it's time from the system clock on the Dashboard PC, or from network time received by Ultrix?
Thoughts?
David Hidden
Senior Technical Operator
Kojo
Sent: 02-13-2024 16:44
Subject: Ultriscape timeofday clock
Hi Mark,
in your layout editor there is a tab at the top, dedicated to setting the different clocks.
You can also add a differnt clock in the same interface.
Mike Pomerleau
