Just want to confirm: Is this a standalone carbonite frame or is one of the SDPE blades configured to be the carbonite? If it is the latter: go to Navigation Menu, configuration, Outputs. These are routable, you can change these to be any of the AUX buses. Once you identify the position, you should be able to find and trace it within the database. Your Carbonite Outputs are likely already in your Ultrix database. I believe all you would need to do is create a route to an available Ultrix output using a router panel within Dashboard. If you do not have this already set up, I highly recommend giving Ross Video Tech Support a call.
Karina Flores
Demo Artist
