Hello all,
I am trying to change the timing of a macro I built, but I cant figure out how to do so. Any help with extending a DVE Param shift time would be greatly appreciated!
See attached pic.
!(https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/UploadedImages/vj22JS9dQPKQosFafeDY_Screenshot 2024-08-01 at 11.24.46 AM.png)
Hi Zachary,
May I clarify that you would like to set the DVE X-position at 0%, wait a predefined amount of time while ME2 transitions, and then set the DVE X-position at 36.2%?
To achieve this, insert a PAUSE event after the ME2 transition event.
Custom Control > Pause > Set desired duration for the pause
Thanks for the reply, Aaron. I would love to see the transition happen live (The key shifting from left to right smoothly over 2 seconds).
Would you happen to know if that is possible?
Hi Zachary,
I think I understand now - you would like to animate the transition. Yes, this is possible!
So the animation will be achieved using Memories. Then the memories can be inserted into a Custom Control if you would like the animation to be a part of a larger sequence of events.
You will need to create 2 different memories: one with DVE param at 0%, one with DVE param at 36.2%
Set Recall mode to Effects Dissolve; and Effects Dissolve duration to 2 seconds
Since our focus here is the DVE key, turn on key attributes for the relevant key
Save the 2 memories.
Now when you recall and toggle between the 2 memories, the switcher will interpolate the 2 different DVE parameters over 2 seconds.
For a better understanding of memories, look at these 2 links.
https://www.rossvideo.com/resources/ross-university/carbonite-store-and-recall-memories/
https://rossvideo.community/discussion/carbonite-attributes
The Carbonite U video (first link) is admittedly getting old, with an old color scheme and layout for the UI, but the concept still holds.
I got it to work, Aaron!! Thank you SO much for your assistance!
